Equalization
Leotaurus1975
Equalization
Post by Leotaurus1975 » Thu May 20, 2010 9:40 am
Hi all,
I use Audacity as part of restoring my collection of 78rpms. Especially the Re-Equalization function is enormously important to me...
However all equalization (presets) curves suddenly disappeared from Audacity. I have removed and reinstalled Audacity several times, rebooted my computer but to no avail. I'm using a Dell Studio (64bits) with Windows Vista. It all worked fine untill the curves just went away. All other effect functions work fine...
What to do?
waxcylinder
Re: Equalization
Post by waxcylinder » Thu May 20, 2010 1:02 pm
That's odd - my 1.3.12 still has the following 78 EQ curves (amongst other EQs):
Decca FFRR 78
Columbia 78
EMI 78
RCA Victor 1938
RCA Victor 1947
and my own "custom" inverted RIAA EQ curve
The tutorial in the 1.3/2.0 manual on trnscribing 78s: http://manual.audacityteam.org/index.ph ... pm_records
has a link to a page in the Wiki for a set of 78 playback curves - see: http://wiki.audacityteam.org/wiki/78rpm_playback_curves
And I believe that the developers may have plans to simply the set of preset EQ curves that are available, but to put easily downloadable curves for 78s and other unusual EQ curves in the Wiki.
whomper
Probationer
Re: Equalization
Post by whomper » Thu May 20, 2010 1:26 pm
it would be far better if the developers put it all in one package
instead of making us dl other stuff
the average user cant dl and install anything without their teenagers help
waxcylinder
Re: Equalization
Post by waxcylinder » Thu May 20, 2010 3:21 pm
whomper wrote:it would be far better if the developers put it all in one package instead of making us dl other stuff
Personally I'm inclined to agree - but the dev discussion spent some time on weighing the pros and cons of having an overloaded drop-down list with specialist options (like 78 EQ curves) which only a few specialized users would need - and they wanted to opt instead for a concise list with options that most folks would be likely to need.
Trebor
Re: Equalization
Post by Trebor » Thu May 20, 2010 9:28 pm
Leotaurus1975 wrote:However all equalization (presets) curves suddenly disappeared from Audacity. I have removed and reinstalled Audacity several times, rebooted my computer but to no avail. I'm using a Dell Studio (64bits) with Windows Vista. It all worked fine untill the curves just went away. All other effect functions work fine...
What to do?
You may have to modify a hidden file called "audacity.cfg" to get your reinstall to work ... http://forum.audacityteam.org/viewtopic ... 878#p82878
The location of "Audacity.cfg" (config) in Vindows Vista
The location of hidden file 'Audacity cfg'.jpg (42.55 KiB) Viewed 1702 times
If your equailzation curves were custom made they are in"EQCurves" (see above screen-grab): save a copy to avoid having to remake them if the problem recurs.
Leotaurus1975
Re: Equalization
Post by Leotaurus1975 » Fri May 21, 2010 8:42 am
Thank you for you input. I have followed the instructions and then restarted Audacity... The problem continues. The equalization curves are just flat, although the presets are visible in the equalization menu, all curves are flat. In did not customize any curves...
Trebor
Re: Equalization
Post by Trebor » Fri May 21, 2010 7:16 pm
Are you reinstalling a fresh copy of Audacity from the sourceforge site ?.
[If you are reinstalling the same damaged files from the copy on your computer the problem will recur].
