Frequency correlation to SPL reading
kage012
Post by kage012 » Thu Feb 25, 2010 1:00 am
Hi,
So I'm working on a project in which I'm trying to reduce the overall SPL of our mechanical system. I have a simple radioshack SPL meter to give me an average dB reading. However, I would like to find the dominant frequencies in my system, thus I downloaded Audacity (the newest version from FileHippo.com). I've recorded my system and when I use the "Plot Spectrum" feature in the "Analyze" drop down menu, all the dB readings are negative. From other postings that I've read in this forum, I've gathered that the dB displayed in the plot cannot be directly correlated to the dB reading on my SPL during my tests (I ran both simultaneously). However, is there a way to use the spectrum plotting feature to determine what frequencies are relevant at my dB level? I have no experience in the audio field whatsoever so I'm pretty much learning as I go. Thanks for any help you can give.
-Kyle
Re: Frequency correlation to SPL reading
Post by kozikowski » Thu Feb 25, 2010 4:53 pm
Note the two "curves" on your instrument, A and C. Hazard laws and your ears work in curve A -- sensitive to some frequencies over others.
http://en.wikipedia.org/wiki/A-weighting
"C" is more or less flat. We need to know whether you are dealing with law enforcement or not. Curve C is a snap to manage and measure. Curve A is a good deal less so.
Post by steve » Thu Feb 25, 2010 6:13 pm
kage012 wrote:(the newest version from FileHippo.com)
To be sure of having the latest version, download the latest version from the Audacity web site: http://audacityteam.org/download/
The current version is 1.3.11
kage012
Post by kage012 » Thu Feb 25, 2010 7:45 pm
We're using the C weighting. Sorry, I should have mentioned that in my earlier post.
-Kyle
whomper
Probationer
Post by whomper » Thu Feb 25, 2010 9:51 pm
kage012 wrote:Hi,
-Kyle
db will be negative!
all relative to absolute loudest digital can be
but all are still relatively correct to each other
the peaks on the display show the freqs that are loudest
the spl uses a weighted average of all of them
but as a rough guide - the loudest (tallest-least down) add the most
so if you have big peaks you gain a bunch by fixing them
if its all relatively flat you need to lower everything
and of course
adjust that advice by the weighting curve if you need it
some freqs may be more annoying than others for
human hearing ability and psychology reasons
Post by kozikowski » Thu Feb 25, 2010 10:16 pm
<<<db will be negative!>>>
He's right. Digital Audio is measured from maximum possible and always goes down. Maximum possible is 0dBFS -- zero dB Full Scale. Standard reference broadcast tone in the US is -20. In the UK, it's -18. the numbers always go down. Higher than 0 is where your computer explodes or other very nasty evil things happen.
Sound Pressure Level, I believe can go both ways, but it doesn't make any difference. If you do something and a particular peak in the spectrum analysis goes down 6dB, then the sound energy at that frequency will go down by half. This is the singing bad bearing or whining compressor thing.
This is where experience counts. Knowing what each frequency sounds like is a big deal. This is an engineering joke. Two engineers listening to a broken motor screaming. "3500 Hz," says one. "More like 5000 Hz," says the other. Then they run for the analyzer to find out who has to buy the beer. Usually, they leave the motor to burn up.
Post by kozikowski » Thu Feb 25, 2010 10:18 pm
Just when you're feeling fuzzy-warm about all this. What are you using for a microphone? They all have frequency lumps and bumps, too. Your Radio Shack meter should have an audio output on the side.
kage012
Post by kage012 » Sun Feb 28, 2010 5:28 am
The microphone we are using is called a Rode NT1 I believe. So if I have a waveform spectrum and say I do something to our system that quiets it. If I were to plot the spectrum and if the the 500Hz peak was initially at -27dB but is now at -37dB, I've effectively reduced the SPL by 5dB?
When I was playing around with the settings in Audacity, I did Preferences>Interface>Meter/Waveform dB range and set it to -120dB (Approximate limit of human hearing). Do I need to even adjust this setting? Intuitively, to me anyway, none of the other settings seemed like they needed to be changed. Although, like I said I really don't know what I'm doing. I changed it because I wanted to make sure to record all relevant frequencies within our range of hearing. Changing this setting seems to have some impact on the reference value in the Waveform Spectrum plots. Is this adjusting the reference pressure used in Audacity's dB calculations or something?
Here's a plot of one of my recordings. It looks to me like the dominant frequencies are between 300 and 600Hz and then less than 200Hz with some less-notable spikes elsewhere in the spectrum. Generally speaking, the nature of the frequencies seem to tail off as the frequencies increase.
http://dl.dropbox.com/u/1995316/Waveform%20Spectrum.bmp
Post by kozikowski » Sun Feb 28, 2010 7:48 am
That tailing off thing is suspicious. Nature doesn't do that. There's something in the sound pathway that's producing an artificial droop.
The Rhode isn't really flat and you have to factor in the lumps and bumps of its response.
Picture 1.png (48.58 KiB) Viewed 2068 times
Stand in front of the running system with a sheet of newspaper and crumple it up. Be careful not to overload the sound channel. Do an analysis. That should produce measurable energy out to 20KHz.
Post by kozikowski » Sun Feb 28, 2010 7:52 am
You can get much more accurate displays and peaks by increasing the sample frequencies. Note the numbers on the bottom of this...
http://kozco.com/tech/audacity/piano_G1.jpg
Also, the displays get much better as you make the window larger.
-70dB should be well beyond the limit of human hearing.
