Chain - amplify without clipping?
sagetyrtle
Post by sagetyrtle » Wed Jan 27, 2010 7:01 pm
I've only just discovered Chains and I'm wondering if there's a way to create a Chain to do the following:
Effect :: Amplify :: Ok
(Because the "allow clipping" box is unchecked, the default Amplify value is always all right.)
I run this particular small series of commands at least three times a day.
Thanks very much for any help you can give,
-Sage
Re: Chain - amplify without clipping?
Post by kozikowski » Wed Jan 27, 2010 10:34 pm
Chains is in preliminary baby steps and the effects available have been hand-created to work. If your effect isn't in that list, it may have to wait for more development. At current, there's no way to create your own chain -- that I know of. Audacity will not script.
There's no shortage of people wanting to turn Audacity loose and come back later in the week to collect the finished sound files.
billw58
Post by billw58 » Wed Jan 27, 2010 11:00 pm
You can create your own chains using the information here: http://manual.audacityteam.org/index.ph ... dit_Chains
And apply them with the information here: http://manual.audacityteam.org/index.ph ... pply_Chain
Unfortunately, the Amplify effect is not so useful in Chains, as it merely stores the amplification factor and does not adjust itself with each application of the chain. The Normalize command may be more appropriate as it always calculates the amplification factor needed to meet maximum peak amplitude. Normalize does, however, treat each channel of a stereo track separately. This is rarely an issue, but in extreme cases can alter the stereo balance of a track.
I'm not sure that having a Chain that simply calls the Normalize command would save any time unless you combine it with an export step in order to batch process a bunch of files.
-- Bill
Post by kozikowski » Thu Jan 28, 2010 2:58 am
List went way up since the last time Iooked. This happen around 1.3.10? I know I can't do most of that in 1.3.7.
