A text editor
dinosaur
A text editor
Post by dinosaur » Mon Nov 30, 2009 12:18 am
Hello,
I do a lot of voice transcriptions and end up writing the transcriptions in 'Label" . This is not the best way to do this as "Label" doesn't keep things lined up well. Nor can I get it to output to a text file.
Would it be possible to get some kind of an editor that would take the place of 'Label"? I get very short sections of voice that can take up pages and other sections that don't. Also different speakers need to somehow be delineated. I was thinking that the easiest way would be to have 'Label", or a text editor, be able to use several different colors for text that would be readily at hand. Each sound section "grayed out" could go to a different page.
Thank You.
Irish
Forum Crew
Re: A text editor
Post by Irish » Tue Dec 01, 2009 4:42 pm
If you Export your label track (File > Export Labels), Audacity creates a text file containing each label's text and its position on the timeline.
The rest of what you want can be done in your text editor.
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
dinosaur
Re: A text editor
Post by dinosaur » Tue Dec 01, 2009 5:37 pm
Thanks PO'L,
That didn't occur to me. Will try it.
