Import this format as Raw Data?
citylife
Post by citylife » Fri Nov 20, 2009 8:10 am
Hi, I'm trying to find a way to convert the Sony proprietary format .dvf to .wav or .mp3. I tried to import it as raw data, but I'm only getting a long hiss.
I know there is a converter from Sony, but Kaspersky is marking Sony's drivers as a "potentially dangerous" program, and until I figure out what to do about that, I need to find an alternative solution.
Does anyone have any suggestions as to what I can do (appropriate raw data settings, for example), short of plugging the recorder itself into the line-in and recording the old-school way?
Thanks in advance!
Irish
Forum Crew
Re: Import this format as Raw Data?
Post by Irish » Fri Nov 20, 2009 11:45 am
"Switch" is one program which will convert .dvf files, though it says that not all dvf recorders are supported.
It is a free download from http://www.nch.com.au/switch/
There are probably others too.
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
