Extending play time?
asanchez_hb
Post by asanchez_hb » Thu Nov 05, 2009 11:15 pm
I want to use a doorbell for a sound effect in an upcoming show, but the doorbell I want to use cuts a little bit short at the end...how could I elongate this so that it doesn't sound so cut off?
Thanks for your help.
Jason
billw58
Re: Extending play time?
Post by billw58 » Fri Nov 06, 2009 1:11 am
Did the recording of the doorbell end before the sound of the doorbell completely died out, or is the doorbell sound just too short?
Try Effect > Change Tempo with a negative value - this will make the sound longer without affecting the pitch.
If the recording was cut off, you could, after changing the tempo, use Effect > Fade Out.
-- Bill
Post by steve » Fri Nov 06, 2009 9:46 am
What sort of doorbell?
"Ding-Dong", "Brrrring", other?
Trebor
Freesound
Post by Trebor » Sun Nov 08, 2009 5:55 pm
Freesound has a selection of free doorbell samples, e.g. plenty doorbell here ... http://www.freesound.org/samplesViewSingle.php?id=18761
