JTP_60:
I tried to invert the "S"-track but it made no difference, but I could not find "Invert Phrase", just "Invert". I don't know the difference. What program do you use?
Kozikowski:
I recorded in a very low sound setting. It just a couple of days ago that we realized this and raised the volume.
Thank you for the comment on exporting as Wav. I will do that.
Remove lisp.
Re: Remove lisp.
Attached an overly de-essed "before & after". Audacity, Spitfish, Windows.Machabees wrote:So why do they have plugins that say they can do it?
Or recommend it in this forum, if it can't be done?
Re: Remove lisp.
What values did you putt in to Spittfish? My result always becomes the opposite, everything but the “S”-sound disappears. I'm following the manual to the dot, as far as I can understand, but it always becomes wrong.
