Filter Curve Macro?
Here’s the goal: Effect > Filter CurveEQ > Flatten.
Can that be done with one instruction line in a Macro? That Macro instruction will be used in combination with other Macro lines. So it doesn’t have to stand alone.
Yes, but it’s not going to do anything …
If you’ve got desired filter-curve parameters into the macro, then everything is good to go.
The secret to getting the correct filter-curve into the macro is to apply that EQ to some audio just before you insert a filter-curve step into the macro, when creating/editing the macro.
Just changing the filter-curve without applying it does not update the filter-curve parameters which will be incorporated into the macro step you are creating.
