Improving the sound of a real piano recording
Trebor
Re: Improving the sound of a real piano recording
Post by Trebor » Sat Aug 01, 2009 9:46 pm
mjwillyone wrote:Wow ... what a difference. I am new to Audacity, but will try to find out where the controls are for doing what you did.
In Audacity 1.3 "Amplify" is at the top of the "Effects" list. Select the section of audio you want amplified, then click on "Amplify", then "OK", simples.
Then use Audacity's (graphic) "equalization", (10th from top of "Effects" list), to boost the high frequencies, (experiment with the sliders).
[As I mentioned above you may have overdid the "noise removal": there are some weird side-effects there which I cannot correct}
Post by kozikowski » Sun Aug 02, 2009 2:33 am
Which is basically what I was going to do, but carried off much better.
How did you get rid of the "noise," and in which Audacity?
I hear phasing caused by a small living room. I know this because this is exactly what my upright grand sounded like in my living room. Some of the notes are way too pronounced compared to the others because those are the notes that the room "likes."
But much more deadly is the reverb and echo. You can pour additional echo chocolate sauce on top and hope nobody notices, but your rose and beige wallpaper, Agatha Christie collection, and paisley divan are always going to be part of your performance.
The microphone has a cardioid pattern. Can we assume you can't turn it off?
We need to congratulate you on not making any of the other common mistakes; overload, clipping, channel noise, etc.
Make another recording, this time without the instrument. Sit in the players position and clap a couple of times with maybe three or four seconds between. I'm after a good solid pop with your hands, wait, pop. You may need to reduce the channel gain so as not to overload anything. I'd like the whole performance from a couple of seconds before to five seconds after.
Post by kozikowski » Sun Aug 02, 2009 3:20 am
Is that serendipitous or what...
http://www.kozco.com/tech/audacity/pianoRecital.wav
(stiff download).
Please excuse the noisy transmission. I've been going back and forth between the two. The Real Thing is a Steinway in Lincoln Center, so that's the gold standard. I think a lot of the mush in the posted sample is the room. You can't get crisp notes in a very echoey hall or a live room.
In spite of being a smaller instrument, the posted sample bass notes are way louder than the standard. This can be caused by instrument design...or a live room.
Plus, I think there's channel distortion on top of everything else. That's why the notes sound harsh compared to the pro recording. The 990 microphone is $49. It's a copy of a Neumann at $4000.
Large cell condenser microphones do have interesting problems. They don't much like sound coming in from the sides. Anything not arriving straight on to the capsule causes ripple distortions. Building and shielding that capsule is a major industrial secret.
Post by steve » Sun Aug 02, 2009 6:47 pm
mjwillyone wrote:The power from the mic is coming from an electrical outlet.
How exactly? According to the manual, "This unit requires phantom power at 48 volts, +/- 4 volts." So what is providing the 48 volts - are you getting the phantom power from a mixing desk, a special microphone power supply, a microphone pre-amp....? (It can't be coming from the laptop, and it can't be coming from a normal wall outlet socket, so I'm left wondering where it is coming from).
[Edit] Oh, hang on a minute - you said that you have a "Eurorach UBB02" - I guess you mean a Behringer Eurorack UB-802 ? That would make sense - you have phantom power switched on from the UB-802 mixing desk.
mjwillyone wrote:The microphone was placed on the floor (on a small stand) on the side of the piano.
Not ideal - you need to get the microphone up higher (try lying on the floor and listening to someone playing the piano - it doesn't sound as good as when you are sitting at the piano, or listening from across the room. Much of the natural timbre (and volume) will be lost if the microphone is too close to the floor.
There are many techniques for mic'ing upright pianos depending on the kind of sound that you want and what you have available. Some people like to open the top of the piano, or even take the entire front off, while others prefer to keep it closed up. I presume that you normally play with the piano lid closed and that it sounds good in the room when you listen "live", so I would probably record with the lid closed (though I may just try it out with the lid open to see how it comes out).
A common microphone arrangement is to use a pair of omnidirectional small diaphragm condensers quite close to the piano (1 to 2 meters away) and a large diaphragm condenser further back in the room (works nicely for pianos in big rooms - you can adjust the amount of "room ambiance" by adjusting the mix). With just a single microphone in a modest sized room I would try placing the microphone in it's cradle (spider) on a full size microphone stand, so the the microphone is just above and behind the head of the pianist (so that it is "listening" over the pianists head). This should give a close approximation to what you hear as you play, and with the equipment you have should give a sufficiently detailed sound that we can hear the pianist breathing, hear the leather on the piano stool creaking, and hear if the pianist has not cut their fingernails short enough.
For the Beauty of the Earth - piano help.zip
Not quite there is it. The amount of noise reduction has caused very noticeable wobbling in the sound - noise reduction should be virtually unnecessary for this kind of recording - what sort of noise are you getting? is it hiss?
[Edit] Now I've twigged that you are using a UB-802, make sure that you have the microphone gain set at a high enough level (but not turned up to maximum). You should be getting a meter reading on the mixer of up to 0dB with the volume sliders set at zero (centre position), then adjust the recording level of the sound card (use the "Line in" on the sound card) so that you get around about the level (or perhaps just a shade higher) than the audio sample that you posted. With all the gain levels set correctly and the microphone positioned higher the raw recording should sound very much better. (nice piano playing by the way)
Post by kozikowski » Mon Aug 03, 2009 5:56 am
There is one more possibility. An old staging trick is to put the microphone upside down so the capsule is only a half-inch or so from the floor. That will dramatically reduce one source of echo (the floor) and double the loudness of the signal. The theatrical version of this is the foam blobs on the floor just beyond the footlights like the EV Mic Mouse.
http://www.electro-voice.com/download_d ... p?doc=2333
Page 3, Figure 5.
Post by kozikowski » Mon Aug 03, 2009 6:00 am
Learned books have been written about how to mic a piano, this isn't a simple problem.
Post by steve » Mon Aug 03, 2009 1:44 pm
kozikowski wrote:There is one more possibility. An old staging trick is to put the microphone upside down so the capsule is only a half-inch or so from the floor. That will dramatically reduce one source of echo (the floor) and double the loudness of the signal.
I don't think that is likely to be a suitable solution in this case because the floor is carpeted and will probably produce rather muffled results due to the carpet absorbing the higher frequencies. It is very likely that this is one of the reasons that Mikes original recording is lacking at the high frequency end.
The basic idea that you describe there is nevertheless valid. In my previous abode I had a pair of PZM microphones permanently glued to the ceiling in the living room and achieved some very nice "ambient" recordings of ensembles with a minimum of fuss setting the recording equipment up (just plugged the microphones into my Sony 1/4" tape recorder, switched on the microphones and start recording).
kozikowski wrote:Learned books have been written about how to mic a piano, this isn't a simple problem.
A lot of the difficult compromises arise when the job in hand is sound reinforcement. In order to achieve a high degree of amplification it is usual to mic up the sound board. This will tend to produce a less natural piano sound, but the type of sound that has now become so familiar that makers of electronic stage pianos will often model the sound on a "Mic'd up piano" rather than on a real acoustic piano.
Microphone positioning makes a huge difference to the final recording. As you say Koz, there are many learned books on the subject, but when commercial pressures and time constraints are not an issue, a lot can be gained by experimentation.
Post by kozikowski » Mon Aug 03, 2009 4:00 pm
<<<will probably produce rather muffled results due to the carpet absorbing the higher frequencies. It is very likely that this is one of the reasons that Mikes original recording is lacking at the high frequency end.>>>
Perfectly true, but you can help that in post production. What you can't fix in post production is the comb effect caused by the echoes. See page one of that document and that, to my ear (what there is left of it), is the most damaging part of the performance.
Not the player. That part is fine.
Listen to the difference between the Lincoln Center performance and the posted one. The high notes are respectable on both, but the mids and lower make my ears bleed.
Still waiting for that clap.....
Post by steve » Mon Aug 03, 2009 4:46 pm
kozikowski wrote:What you can't fix in post production is the comb effect caused by the echoes.
I suspect the comb type effect that you can hear in Mike's clip is caused by Noise Removal rather than the acoustics of the room. It would be helpful to hear a "straight" (unprocessed) recording. In well damped rooms (carpets and soft furnishings), comb effects are usually barely noticeable, whereas in that recording they are very pronounced, which makes me suspect that the cause is something other. There are also other tell-tale signs of not-so-subtle Noise Removal.
kozikowski wrote:Listen to the difference between the Lincoln Center performance and the posted one.
Will do (not listened to those yet).
I hope that we hear from Mike again - there's a lot of good information here and it would be nice if he was part of this discussion.
Post by kozikowski » Mon Aug 03, 2009 4:55 pm
<<comb type effect that you can hear in Mike's clip is caused by Noise Removal>>>
Did we ever establish if he was in Audacity 1.2? I, too, would kill to get a straight capture.
