Your experience with Waves OVox effect
Have you tried using the Waves OVox Vocal Synthesis VST plugin with Audacity? Does it work? What was your experience?
Here’s a link if you want to check it out. Would be cool if it works :wink:
https://www.waves.com/plugins/ovox-vocal-resynthesis#how-do-you-sound-with-waves-ovox
Thanks to all!
Fred
Looks like 64-bit VST3 …
https ://www.waves.com/plugins/ovox-vocal-resynthesis#tab-tech-specs|tab-supported-hosts
So not compatible with Audacity.
Maybe load it into a stand-alone VST host, then record the output with Audacity.
