Héllo,
How can I use Audacity to generate tones which are nolinear based ?
Here some samples draw that I want to generate :
Héllo,
Do you have an equation for the waveform ? … https://forum.audacityteam.org/t/expression-generator/45227/1
Or an example you can copy … https://forum.audacityteam.org/t/arbitrary-wavetables/48262/1
The first one is easy using “Nyquist” scripting.
Apply this code via the “Nyquist Prompt” effect (See: Nyquist Prompt - Audacity Manual)
(setf bias 0.5)
(setf hz 100)
(setf amplitude 0.8)
(scale amplitude (osc-pulse hz bias))
For more complex examples, as Trebor wrote, see this plug-in: Expression Generator - #2 by steve
It is a “Nyquist plug-in”.
Installation instructions for Nyquist plug-inson Linux: https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_linux.html#nyquist_install
