how do you change it to a "supported audio format"?
Nyx
Post by Nyx » Mon Jul 20, 2009 6:22 am
The song i have in says that i need to change it to a supported audio format before i can play it. I have no idea how to do this or what this means
Re: how do you change it to a "supported audio format"?
Post by kozikowski » Mon Jul 20, 2009 6:40 am
The digital music file was created using a technique that Audacity doesn't know about. There are many different digital encoding techniques running around and they all do one thing really well at the expense of everything else.
You can convert music files between different methods using iTunes, Super, or Switch; all separate programs. Audacity likes WAV or AIFF files in 44100, 16-bit, Stereo or 48000, 16-bit, Stereo. That's the Music CD standard and Digital Television Sound standard, resp.
Nyx
Post by Nyx » Mon Jul 20, 2009 4:07 pm
Thank you it is working now!!! :D
