Workflow improvement suggestion: Auto-select all if nothing was selected when applying fx
hardyharzen
- Operating System: Linux Debian
Might be my particular use case, but I often import diskwritten WAVs to normalize and export as MP3 for further distribution. This currently requires selecting the entire audio file beforehand, as normalize will fail if passed no selection. Selection does not persist post fx application, either, so one has to repeatedly CTRL-A, which got me wondering if it wouldn't be more efficient in general to automatically select all audio when no audio was selected while applying fx, or maybe introduce an optional setting for this behavior if it's deemed too impractical for general use cases.
Re: Workflow improvement suggestion: Auto-select all if nothing was selected when applying fx
There is an option in Preferences: "Auto-select, if selection required:"
See: https://manual.audacityteam.org/man/tra ... ences.html
hardyharzen
Oh, woe is me! Well then, thanks for the heads-up! /topic
