Does scarlett 18i20 work with Audacity
Did you buy a new mixer? Do you need advice? Post here.
swedrummer93
Post by swedrummer93 » Wed Mar 08, 2017 5:10 pm
Hi! My name is Johan Martinsson. I've been trying to record drums in Cubase pro 8.5, but have been pulled back to square one all the time. I've been thinking about getting simple, like Audacity instead.
Does the Focusrite scarlett 18i20 work with Audacity? Thankful for answers.
Re: Does scarlett 18i20 work with Audacity
Post by kozikowski » Wed Mar 08, 2017 7:28 pm
What does that mean in different words?
Our latest generation 18-in, 20-out USB audio interface can handle just about anything your band or studio can throw at it
That's scary. Audacity can manage multi-track recording, but it's a little hit or miss depending on the device.
It doesn't cost anything to try.
http://www.audacityteam.org/download/windows/
You should dig in the device information and find out if it supports Windows 10. It has to say that in those words. Windows 10 is a whole new system and many older devices and software packages stopped working.
Post by kozikowski » Wed Mar 08, 2017 7:30 pm
If the word "ASIO" goes by, Audacity doesn't easily support ASIO. So that will be full stop.
Ed_Focusrite
Post by Ed_Focusrite » Wed Mar 15, 2017 4:23 pm
Hi Swedrummer93,
Information on using the 18i20 with Audacity can be found here:
https://support.focusrite.com/hc/en-gb/ ... s-and-OS-X
In short, on Windows, for most drum recording applications it is not possible as you can only see the first two inputs in Audacity.
Post by Gale Andrews » Thu Mar 16, 2017 1:31 pm
Ed_Focusrite wrote:Information on using the 18i20 with Audacity can be found here:
The article means that Audacity as shipped does not support ASIO on Windows. It is possible to compile Audacity with ASIO support, but you must not give that ASIO-enabled build to anyone else due to licensing restrictions.
cyrano
Post by cyrano » Sat Mar 18, 2017 10:39 pm
Steinberg licensing is changing. It seems the latest ASIO version has 2 licenses: Commercial AND GPL. You might want to look into that.
Post by Gale Andrews » Sun Mar 19, 2017 4:06 am
cyrano wrote:Steinberg licensing is changing. It seems the latest ASIO version has 2 licenses: Commercial AND GPL. You might want to look into that.
I have done so, but drew a complete blank. The 2.3 ASIO SDK has a PDF licence application form to send to Steinberg. I see nothing about GPL.
The VST 3 SDK has a dual proprietary / GPL v2 licence: https://sdk.steinberg.net/viewtopic.php?f=4&t=282.
cyrano
Post by cyrano » Sun Mar 19, 2017 10:12 am
You're right, Gale. Sorry.
I got VST and ASIO confused. Now let's hope ASIO might just follow VST licensing?
