3.5mm headset to XLR adaptors please
Did you buy a new mixer? Do you need advice? Post here.
robertc1985
Post by robertc1985 » Fri Jul 11, 2014 4:57 pm
what i am about to ask for may be a little unusual in these forums (i don't know, this is the first thing i've ever posted here, but i am in kind of a tough spot) i need a device that will safely allow me to connect my 3.5mm logitech headset into the XLR of my Behringer Xenyx Q1202 USB mixer. i would strongly prefer not to need to use phantom power but i have seen a user by the name of kozikowski build exactly what i am looking for and if he is out there reading this i am willing to pay you for one of these now, and possibly up to three more later, i do not trust myself behind a soldering iron and my knowledge of circutry is almost non existent. i saw basicially an amplifier connected to an 3.5mm to xlr adaptor. i might be able to come up with the adaptor on my own, but i really need help with the amplifier as i am no good at making home made electronics. if you would please contact me with any way you may be able to help, i would be extremely thankful.
Re: 3.5mm headset to XLR adaptors please
Post by kozikowski » Sat Jul 12, 2014 3:39 am
Never heard of him.
Casting my mind back. Yes, I did create a power supply to allow you to use a "computer" microphone with a Pro mixer (XLR Input).
You have a couple of the terms mixed up and you're in really good company. The volume of sound in both XLR and and computer microphones and headsets is roughly the same. Thank goodness you don't need amplifiers or other exotic electronics.
But you do need a power supply. Computer microphones take 5 volts from inside the computer to work. That's what goes up the ring connection in a tip, ring, sleeve connector.
Second illustration. Scroll down.
http://www.kozco.com/tech/audioconnecto ... ctors.html
That's very different from "Phantom Power" which the broadcast and recording people use on their XLR connectors.
Unfortunately, I know of no way to get between them, which is why I and a number of others manufactured our own. I went compulsive and made very stable 6 volts using flashlight batteries (up from 5v). There is little or no changes in the operation of the microphone with the way I did it. Others more adventurous stuck 9v batteries in there and it seemed to work OK, although there was a discussion of what happens to some of the other components when you do that. A 6 or 7 volt rated capacitor will not work in a 9 volt circuit — for long. This is electronic exotica. Don't worry about it.
Still, I can't imagine that nobody is manufacturing anything like this. I even found people making the reverse adapter. Start with a good quality XLR (non-phantom) microphone and plug it into a computer. Hosa makes them, or you can do it with Radio Shack parts. Hurry before R/S goes bankrupt.
I'm looking for a long posting we did on that. Someone found a way to make one using exclusively screw together components. No soldering.
Searching.
Post by kozikowski » Sat Jul 12, 2014 3:51 am
Here's pieces of it.
http://forum.audacityteam.org/viewtopic ... 27&t=77084
I gotta stop and read through it. I don't remember where the construction notes are.
robertc1985
Post by robertc1985 » Sat Jul 12, 2014 4:34 am
talking with a friend and he seems to want to go the route of regulating the 48 volt phantom down to 5 volts between the pink plug and the 3.5mm to XLR adaptor, however i would like to get as many opinions on this as possible
Post by kozikowski » Sat Jul 12, 2014 5:10 am
I did think about that. The problem is you can't just regulate 48v down by sticking a couple of diodes in there. 48 volts is intentionally a very weak voltage so it doesn't interfere with the microphone signal. It would be like trying to get the electricity from your hair brush (thousands of volts) to run an electric motor. They don't match.
So to pursue that line, you would need a phantom power receiver, a DC to DC converter to make the 5 volts and then the rest of the circuitry to actually get it up to the microphone.
Plus debugging. Microphone signals are really tiny and delicate. I live under the neighborhood high tension lines (4000 volts??) and if I make any error at all my sound starts humming and buzzing.
This is where we join the ROI Cycle where the cost of hardware and development time exceeds the cost of an actual XLR microphone. This is probably the major reason you can't walk to the store and buy one of these.
Did you get far enough in the other dialog to read the construction parts? I know somebody did this with no soldering. He was really determined to get one working.
Post by kozikowski » Sat Jul 12, 2014 5:37 am
robertc1985
Post by robertc1985 » Sat Jul 12, 2014 6:05 am
it's the device shown in this post http://forum.audacityteam.org/viewtopic ... =10#p80958 that i think is what i want, feel free to tell me i am wrong if you think i am, you know more than i do about this it seems, i am just trying to get you or whoever else would be willing to build me one, bucause not only am i crap in the soldering department, but i seem to have the worst luck in circuits that i build for myself i only need one at the moment, but could possibly want 3 more in the future, if you aren't willing to do this for me i would just ask for very detailed instruction to create exactly this (assuming it's what i need, and if not than instructions on what i do need) to pass along to a friend, i'm sorry i can't quite grasp all the other threads, i am running on about 4 hours of sleep and even when i've had 8 technical stuff like this confuses me. lol. but i would be willing to pay whatever price we would both deem resonable (if this is allowed here) to get what i need built for me. i am not much of a DIY guy.
Post by kozikowski » Sat Jul 12, 2014 11:00 am
Then the alternate method may be handier. Record each microphone on its own computer. Anything that will do a Skype call should work so people with netbooks or other smaller Windows machines should be able to handle it. At the end of the show, Export the sound files and walk them over (USB Thumb Drives??) to one computer for integration into one show in Audacity.
Each time you Import a new sound file, Audacity will stack it one on top of the other and play them all at once. Use the Time Shift Tools (two sideways black arrows) to shift each sound file earlier or later until they all match. Audacity will add them all up into one show when you Export.
Make sure to start early and stay late. That is, leave a bunch of time before you start the show and after for time fudging. If you start the show before everyone is recording you can have a bad time in post production matching the voices.
Post by kozikowski » Sun Jul 13, 2014 12:32 am
I have posted a product request at Sweetwater Sound. This may be the second time I requested this. I lose track. I send people over to them all the time and I have an account there. I really like their product illustrations and technical details. I don't have to dig for stuff, so I interrupted their string of promotional messages for a "real" message.
"Look, if you really want to be valuable...."
Post by kozikowski » Sun Jul 13, 2014 1:22 am
And speaking of Sweetwater, I have used this AKG microphone.
http://www.sweetwater.com/store/detail/C555L
I used it with the battery adapter, but you can get an adapter that allows you to use it with 48 volt phantom power from a mixer such as your Behringer.
