You though this was going to be simple.....So what you're saying here is that I'd better not go for an audio interface because of the fact that my microphone only records one channel, am I right?
As I don't own a Scarlett, I can only guess at it from anecdotal evidence. It's possible through software drivers you can steer any microphone to any output or create mono or stereo. I just don't know. I know the Shure X2U will record in either stereo or mono with Audacity -- I just tested it -- so all the bases are covered. I also know that when people have troubles with the Scarlett they seem to be arm wrestling with the software, not the actual device.
The problem with mixers is there is no way to hide the controls you will never use. I did a dog and pony show at work and I made a picture of our mixer where I blocked out all the knobs they don't use for day-to-day operation and will probably never use. It looked much more manageable when I did that. The PV6 will happily mix a podcast with four live microphones and two music players, so yes, you will only be using a very small fraction of what it can do. I can't remember ever sending more than one microphone through mine.I'm a bit afraid of buying one of those because they look terribly intimidating.
But I know it works and I hold onto proven equipment with white knuckles.
It does, but when you shrink smaller than about that size, you start getting equipment that takes shortcuts or has unfortunate features you really don't want. I would kill to have my X2U do what I want. It's got all the parts, indicators and controls, it's convenient (I have a picture of it sticking out of my jeans pocket) and it sounds good after you amplify the work loud enough.it seems these have way more inputs than I need.
What's the show? I don't think you ever told us what you're doing.So if I'd buy a peavey, what do you think would be the best way to go? Buy the one you have with a digitalizer, or buy the second one that can immediately connect through USB? Or is there not much difference there?
There is an additional group of microphones that can be damaged by plugging into Phantom Power by accident. Any sound professional will make sure Phantom Power is not applied anywhere it's not wanted or needed first thing. It's one of our "land mine" problems.What's the benefit of having and off and on switch for the phantom power when it doesn't affect the mics that don't need it?
See illustration. I have one of those microphones. It's one of the models that can be reduced to garbage by plugging it in with Phantom Power running. So this problem is not an academic fairy tale. It's sitting in a box next to me.
