I'd like to record ultrasounds, so I thought about replacing the standard electret microphone in a cheap 3.5mm jack mic with the Panasonic WM61 electret mic which is know (http://www.wildlife-sound.org/equipment ... index.html) to pick up frequencies above 22kHz.
At this point, I'd need something which can handle 96kHz or even better 192kHz sample rate in Audacity.
I've found some cheap USB adapters with a mic in and headphones out, though I don't know if they'd handle such a high sample rate (not listed in their features).
At this point I'm stuck and I don't want to spend way over $60, so I'd need either a workaround or some tips from you.
After all I'll just need to view those above frequencies in Audacity's spectrum, not listen to them
Thank you
