My understanding is the 16/44.1 is sufficient for high quality playback. There have been several extensive studies using double blind testing and they all agree that people cannot tell the difference between a good quality recording played back as 16/44.1 or higher format, when played at moderate to loud volume level. If very quiet music is played back at an extremely high playback level, then some listeners are able to distinguish improved quality at 24 bits, but watch out for the loud bits - you could damage your hearing.Soak wrote:So, if I understand well, a CD quality is like the best we can find (16/44.1)?
Extra bit depth does no harm (except for the additional file size). 32 bit float is an excellent format when processing audio because of its extreme accuracy and it is virtually impossible to clip (except in the playback system).
Back in the days when CD audio was invented, 44.1 kHz was barely enough. The old anti-aliasing filters were not that great, so the high frequency response would typically start rolling off at around 16 kHz. Modern digital filters are much better, and even cheap CD players are capable of accurately producing frequencies very close to 20 kHz (which sadly I am no longer able to hear, though I can still measure them
I have come across some 24/96 systems that sound better at 96 kHz, and have come across other 24/96 systems that sound better at 44.1 or 48 kHz, so to some extent there seems to be some dependence on the implementation. Some sound cards seem to have a "sweet spot" - settings at which they work best. There are some 24/96 sound cards available that sound much worse than equivalently priced 16/44.1 sound cards.
The psychological effect should never be underestimated - it is a very real effect. It has been clinically proven that the placebo effect has medical benefitsSoak wrote:and the majority of people find the sound better in 24 bits. So, what the point about this, its it just psychological?
Because vinyl IS better.Soak wrote:2nd question: Why the vinyl sound better?
Have you ever met anyone that loves their CDs?
People may love "the music" on their CDs, but no-one loves CDs in the way that people love their records. There's something about the ritual of playing a record that makes it all the more worthwhile - you don't just grab it off the coffee table and stick it in the player. You handle it with care, place it on the turntable and lower the arm, then sit back and appreciate it. It's like the difference between a painting and a photocopy.
You can only tell so much from a frequency plot - the real test is in the listening, but I'd guess they both sound pretty similar.Soak wrote:3rd question: What is your analyze from these two graph for a comparison, which sounds the better or there is no difference?
