I come here because I have a big problem when ripping vinyles and I don't know what to do. Visibly I miss some bandwith when I try to record more than to 48 kHz.
My equiment
Turntable: Audio Technica AT-LP120-USBC
Cartridge: Audio Technica AT-95E (MM)
Phonoamp: I use the one built-in in the turntable with the Line output directly on my audio interface
Audio Interface: Steinberg UR22 (24 bit 192 kHz USB)
Audio Capturing: Steinberg Cubase AI Elements 7 (ASIO-Driver)
Some pictures
- To connect RCA output to Jack input on the audio interface (in the MIC/LINE inputs):
- Audio interface:
What I obtain with these settings (look from the audio interface picture):
Recorded at 96 kHz, only 44.1 or 48 kHz are present in the bandwith I think, because when I convert the file to 48 kHz, the full bandwith is here.
So here's my question: what do I need to do? Try to adjust the input gains on the audio interface or buy a new pre-amp like a Cambridge Audio 651P?
Thank you
