Did you buy a new mixer? Do you need advice? Post here.
- Site Admin
Post
by steve » Tue Feb 19, 2013 2:10 am
andreiu wrote:Are you telling that I cannot use the ART box also for listening the music from my PC ?
The ART manual is available here:
http://artproaudio.com/discontinued_pro ... o_plus_v2/
It looks like you can use the device also for listening to music from your PC.
- Site Admin
Post
by steve » Tue Feb 19, 2013 6:47 am
The current "Project Series" USB Phono Plus provides monitoring of the phono input, or the computer output or both via the headphone socket (switchable from the from panel with a separate monitor level control).
The RCA outputs are direct from the phono input which allows the unit to be used as an ordinary phono pre-amp without the computer connected but does not play back from the computer.
There are 2 optical digital connections, one for input into the computer and one for playback from the computer.
There is on S/PDIF co-ax input for input into the computer (when connected this overrides the optical input).
