Problem using PC headset mics with a Yamaha audio mixer...
acousticdj
Re: Problem using PC headset mics with a Yamaha audio mixer.
And you know I wanna say I thought that this mixer did take mics in the 1/4" openings on the first two channels but I couldn't find it in the book for the life of me or remember for certain. I also don't have an xlr mic to 1/4 male adapter to plug my regular dynamic mic in to try it. I'll keep looking. It would be alot nicer to use the 1/4's. Thanks for the heads up bout the black bands.
acousticdj
From the Yamaha website!:
" The XLR-equipped stereo channels can accept mono microphone input either via the XLR or phone jack connectors. "
I knew it. Thanks for the reminder to check on that!. You just saved me a chunk of money and work buddy
That's good. I forgot about those screw terminal strips. Maybe the worst problem with those is the capacitor. The leads may not be long enough to reach the screws. If you have the option of getting a capacitor whose leads stick out the ends rather than both on one end, it may fit better. They come both ways.
The 10K resistor can be jammed right across the leads going to the mixer.
He used a 1800 ohm resistor (brown, gray, red) rather than a 2200 (red, red, red) and both would probably work. They're very close.
http://samengstrom.com/24614782/en/read ... olor_Codes
The first three bands are the value and the fourth is the accuracy. Red, red, red, is 2, 2, with two zeros. 2200. The fourth should always be gold. I think that's 5%.
The metal box should be connected to the lead that goes to the shield/sleeves or grounds. That's the bottom wire in that pencil sketch. The metal box then becomes part of the wire shields on both ends and forms a protective bubble around your circuit.
Whatever happens mechanically at the XLR end, the signal has to go to pin 2 and the shields have to go to both pin 1 and pin 3. It's possible to mess with this, but that's the standard. Pin 2 always gets the main show and Pin 1 always gets ground or shield. Pin 3's job changes depending on the type of connection. In your case, it becomes part of the shield system.
Here's another resistor color code diagram with fewer fancy animations.
http://www.csgnetwork.com/resistcolcalc.html
I'm just catching up with the messages. If you use a mono plug into the mixer, just tip and sleeve, then my pencil sketch is the wiring. The long sleeve connection will take care of the extra ring contact found inside the mixer (the equivalent of pin 3 on the xlr).
acousticdj
Just catching up on these posts too. Busy weekend. Made it to the supply house and surplus store but haven't had a chance to put anything together yet.
<<<That's good. I forgot about those screw terminal strips. Maybe the worst problem with those is the capacitor. The leads may not be long enough to reach the screws. If you have the option of getting a capacitor whose leads stick out the ends rather than both on one end, it may fit better. They come both ways.>>>
Found capcitors with "end leads" so hopefully that works.
<<<The 10K resistor can be jammed right across the leads going to the mixer.>>>
Wanna make sure I understand you. Where exactly do you mean if I'm using this layout with a terminal strip?
<<<He used a 1800 ohm resistor (brown, gray, red) rather than a 2200 (red, red, red) and both would probably work.>>>
Got 2.2's. Good to know though.
<<<Here's another resistor color code diagram with fewer fancy animations.>>>
Great diagram. Very helpful indeed.
<<<If you use a mono plug into the mixer, just tip and sleeve, then my pencil sketch is the wiring.>>>
Mono plug is the plan so I'lll follow the sketch. Thanks!
acousticdj
So okay. I just got a crazy idea. Not sure if this is outside of your area of expertise but any advice you have on this would definitely be helpful.
What if instead of using a 9v battery with a resistor, I did the following:
I have an extra computer power supply collecting dust. It's about the cheapest one you can buy but it has several "+5v" pin connectors on it. I've already connected the "grey and green" connectors on the 24-pin connector to make it a stand alone unit that I can use without it actually being connected to a computer.
I also have harnesses to connect to the power supply connectors to create leads. That means... I can make several 5v connections off of the power supply and wouldn't need to use batteries... OR the 2.2k resistors (to bring the 9 volts down to 5)?
Am I even on the right planet? I feel like I'm probably missing something but it would be cool to not have to use batteries. I would still use the capacitors and the 10K resistors of course.
I think I can use the three "red" +5v pins on the big 24-pin connector OR the three heads on the 4-pin cable in a chain and get the same effect. Yes?
It's a basic ATX12V power supply.
http://en.m.wikipedia.org/wiki/Power_su ... (computer)
This one specifically:
http://www.newegg.com/Product/Product.a ... 6817170014
Also on the 1800 ohm resistor: He used a 1/2 watt. I think Steve suggested using a 1/4 watt or 1/8 or 1/16. Not a big deal right?
Thanks again bro. Just wanna make sure I do this right
In reverse order:
The physical size of the resistor doesn't matter in this case. That only matters when there is physical heat -- the parts get hot to the touch and you have to manage the heat. These parts will never see anything like that in normal operation.
Which brings us to the batteries. If you unplug the microphones after each use, the batteries are expected to last almost the shelf life, certainly a year or more. The unit in the pictures has never had its AA batteries changed. I think it's two years old.
And that brings us to the power supply.
Qualified yes. It's a delightful idea to replace the batteries, but you should keep in mind the signals from the microphones are stunningly small. I use the phrases Tiny, Delicate and Wispy to describe them. Putting a wall-type power supply in connects the microphones to the home power system with the clicks and pops every time the refrigerator or air conditioner kicks in. And now we're talking real power, force, horsepower--literally, the power of horses, and heat. Not Wispy.
However. You should try it. You could luck out and everything stays quiet and not have to buy batteries ever again.
The supply system inside the sound card runs from the computer 5 volts and it's happy there. I made two units, one where I actually made 5 volts and the other where I used four AA batteries for six volts. I suspect 9v is the upper end where I would be comfortable running the microphones. Many commercial electret microphones run just fine on one 3v watch battery. Like this one...
http://www.radioshack.com/product/index ... Id=2102927
The volume of the sounds goes up slightly with the voltage, but don't fall in love with that.
Sooner or later, you're going to run into the breakdown voltage of the little transistor inside the microphone and destroy it. The voltage on both sides of the 2200 resistor goes up. The resistor doesn't just soak up the difference. It shares.
The job of the resistor is to bring the 5 volts down to about 1.5. Anything you do over that is pushing it.OR the 2.2k resistors (to bring the 9 volts down to 5)?
I dug in the bags of parts and came up with a "raw" electret microphone element. This one..
http://www.radioshack.com/product/index ... Id=2062216
The specifications on the back are for a maximum supply voltage of 10 volts with a design center of around 4.5v to 5v. The actual voltage of a nine volt battery is 9.65 volts.
Watch your step. Koz
There is a wire going to the tip of the 1/4" plug and a shield wire going to the sleeve of the same plug. This is the plug on the right of the diagram that's going into the mixer.<<<The 10K resistor can be jammed right across the leads going to the mixer.>>>
Those two wires have to go into the terminal strip. Jam one resistor lead and the tip wire into a terminal. Jam the shield wire and the other side of the resistor into another. You're allowed to put two or more things into each terminal -- as many as fit.
