newbie question on usb audio recording
Did you buy a new mixer? Do you need advice? Post here.
paulh
Post by paulh » Mon Jan 09, 2012 5:57 pm
Hi All,
Apologies in advance for the silly beginners question!
I have a few synths plugged in through a mixer and I have...
- Alesis I/O 2
- Cubase LE
- PC running Vista
- Audacity 1.2.6
I record the midi tracks down in Cubase and then I use Audacity to record the audio and export to MP3.
(mainly as I play live over the tracks and mix in realtime)
This has worked fine but I am also now mixing audio vocal tracks with the MIDI in Cubase.
Everything plays back fine but now I can't open Audacity if I have created an audio track in Cubase, so I can't record the complete mix in one hit to Audacity.
as soon as I delete the Audio track Audacity can open and I can record audio again.
Is there any setup I can do to get round this or do I need to get an extra soundcard / USB audio device or is there a virtual option?
I'm on a pretty tight budget so not looking to fork out loads on any hadrware if I can help it!
grateful for any guidance on this!
Paul.
Re: newbie question on usb audio recording
Post by kozikowski » Mon Jan 09, 2012 6:09 pm
There may be a software solution. Download and install Audacity 1.3. Audacity 1.2 does not play well with Vista/Win7.
http://www.kozco.com/tech/audacity/update.txt
bgravato
Post by bgravato » Tue Jan 10, 2012 12:26 am
Like Koz said you should be using Audacity 1.3.14 (latest version). Audacity 1.2.x series are now obselete and have a lot of issues with Vista and Windows 7.
You can get the latest audacity version from here: http://audacityteam.org/download/beta_windows
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
waxcylinder
Post by waxcylinder » Tue Jan 10, 2012 10:34 am
This tutorial should help you too: http://manual.audacityteam.org/man/Reco ... turntables
paulh
Post by paulh » Wed Jan 11, 2012 11:30 am
thanks for the feedback guys, I'll download the latest version and have a read of the links and see what happens!
Cheers,
Paul.
