I am duing interviews with skype and are having problems with the sound..
I have tried to change det settings, but can still not hear the person I am talking with when I am lisening to the recorded interview.
Any good sugestions?
Code: Select all
pcm.!default {
type plug
slave { pcm "jack" }
pcm.jack {
type jack
playback_ports {
0 alsa_pcm:playback_1
1 alsa_pcm:playback_2
capture_ports {
0 alsa_pcm:capture_1
1 alsa_pcm:capture_2
}Also available for Ubuntu - not tried it yet, but installing now - shall have to have a play with this.bgravato wrote:On debian you need to install libbio2jack0
The clumsy VM workaround described earlier provides this - just that the "famous voice" and the "interviewer" are on completely separate recordings. They may drift out of sync eventually, but over a 10 minute Skype chat there's no noticeable drift.kozikowski wrote:The trick is to get the software to put Near on the left and Far on the right of a capture recording.
No vinny you can't. You have been banned again. Please stop spamming the forum.Vinny wrote:I use very good program to record audio and video conversations in skype. It is IMCapture for Skype. I can advise it to you. Try.
