How to tell if I've got usb 2.0 or 1.1?
My PC is 1.5 years old, with windows vista and a motherboard which I believe is the MSI P6N SLI Platinum.
The guys at studio-central (in particular tweak) are keen to stress the importance between usb 1.1 and 2.0
How do I tell which one I have? Ive checked the hardware manager on the usb items, but cant seem to find anything there.
Can I assume that a PC this comparably new has 2.0 ?
Further, tweak asserts that if a soundcard manufacturer doesnt explicitly state what version the usb interface has, you must assume it's a 1.1
When browsing the user manual of the edirol ua-25 ex, I cant find the usb version mentioned anywhere on those 64 pages.
Does that mean it's a usb 1.1 device?
/Jonas
/Jonas
Re: How to tell if I've got usb 2.0 or 1.1?
if it is that new it shoudl be usb2.0 but to be sure
read the manual , visit the pc logo website , visit the mobo website.
ouch. my ua25ex box just says usb. i had thought it was a usb2.0
now i have to dig to find out. it did claim 24bitx96ksamples and other specs that makes me think it should be 2.0 in spite of their generic usb labelling.
yes, normally if they dont say 2.0 you get the older usb speed.
yes, you definitely want the 2.0 until you can get 3.0 real soon now.
avoid usb1.1 for things like audio
now a year or so ago someone bought the maker of that box - came out with sort of a new model in some ways - so if yours is older it may be different usb. i am not sure if they made the box better or just made it cheaper.
cakewalk, roland, edirol, etc., not sure who owns who or who makes/sells what.
be aware there is one labelled cakewalk (newer w/2.0???)
and one labelled edirol (older 1.1??) both have subtitle that says by roland.
this is on the cakewalk seller site
*USB 2.0 Compatible. Works as a USB 1.1 device without changing the specifications and performance. now what the heck is "compatible"? i want one that is totally in conformance with a spec.
from mfgr forums:
it is a mystery (title of thread)
Is Edirol UA-25EX USB 2.0 ?
8 posts - 4 authors - Last post: Feb 27, 2008
In fact they only mention that it is an USB interface. But on some eStore, the UA-25EX is advertised as a USB 2.0 audio interface. ...
forum.cakewalk.com/tm.aspx?m=1598443 -
try these links or google for specs
The UA-25EX is a feature packed, professional-level, ruggedly made 2x2 .... Works as a USB 1.1 device without changing the specifications and performance. ...
not sure if they mean it is usb1 or if it works on usb1 as well as 2
http://www.cakewalk.com/products/hardwa ... od=UA-25EX
Edirol UA25EX from zZounds.com
Specifications Number of Audio Record/Playback Channels ... Read all Edirol UA25EX USB 2.0 Stereo Audio Interface reviews... 10 out of 10 ...
http://www.zzounds.com/item--EDIUA25EX
from mfgr forums:
I've got vista too, I suspect the "USB2 Enhanced" references in device manager mean usb 2.0 ...jonasjar wrote:How do I tell which one I have? Ive checked the hardware manager on the usb items, but cant seem to find anything there.
beyond me - it may be a usb1 device that can run on usb2 pc
it may be a usb2 device that can run on usb1. the manufacturer won't say. vendors claim it is usb2. but they have been known to lie.
why do you really care?
either it runs on your pc or it doesnt.
your pc apparently has usb2 from that screen shot.
alternative
EMU0404 is very similar to the UAex25 and that device's box does say that it *is* usb2 --- if you need usb2 guaranteed try to return your ex25 and get the 0404 else trade it in and get the other one.
The MSI P6N SLI Platinum has USB 2.0 ports (subject to the correct drivers being installed).
The Edirol ua-25 EX is USB 1.1, which is sufficient as the maximum data throughput of the Edirol is 4.6 MB/s and USB 1.1 has a full-bandwidth rate of more than double that amount.
@trebor thanks for the screen dump, unfortunately my own device manager usb-tree differs from yours and doesnt hint at 2.0 like yours do.
@whomper why do I care? because most people seem to rave about "get 2.0, ignore 1.1" when I ask around.
Im being told I will get more latency with 1.1 and that it wont be future proof.
(BTW, concerning latency, is there any big difference if the PC is USB 2.0 and the soundcard is 1.1 vs if both sides are 1.1 ??)
@Steve Where did you get that data throughput on the edirol from? Not from the user manual I assume?
The nickname tweak's statemant that if nothing is said about usb version, then 1.1 must be assumed, seems to be a valid one.
See http://tweakheadz.com/audio_interfaces_2.htm
After checking around, manufacturers seem to be very to keen to gloss over the fact when the usb connection is not 2.0 As I mentioned earlier Edirol doesnt give any hint whatsoever
in the very neat 64p manual of the usb version. Neither is there any hint of bus bit rate in the data section in the end. The only supplier I have found to be candid about this
is focusrite, who says 1.1 over and over in the manual, and even has it printed on the real panel directly beneath the usb socket, in case anyone would have missed it.
About the very few of the major suppliers of simple 2-channel interfaces who sports 2.0 today seems to be emu and tascam. All the other players seem to think that for 2-channel using
an 2.0 interface is not cost effective and overkill, just as steve seem to be hinting at.
BTW, saw some poster on studio-central state that 1.1 was ok for 2 channels, as long as you dont do overdubbing when you record your tracks, someone who'd like to comment on that?
Sorry if I sound picky, but the thought of buying a soundcard, bringing it home and then not having it working as planned, as seem to have happened to quite a few folks, just scares me half to death.
I simply cant afford to buy another one, just because the first one I bought didn't want to cooperate with my PC.
/Jonas
/Jonas
It's possible that you don't have the necessary USB 2.0 drivers installed. Check that you have all the latest drivers for your motherboard - you should be able to get them from the MSI web site. USB 2.0 connections will (usually?) default to USB 1.1 if the correct drivers are not present.jonasjar wrote:unfortunately my own device manager usb-tree differs from yours and doesnt hint at 2.0 like yours do.
I'm not certain about this but as an educated guess it is probably better to have the computer waiting for the sound card than for the sound card to be waiting for the computer. USB 2 on the computer will certainly be no slower than USB 1.1 even with a USB 1.1 device attached - it may be a bit quicker as it should be in a ready state whenever the device needs it. With USB 1.1 on the computer there is possibly a greater chance of a data bottleneck occuring. I've used USB 1.1 audio devices on a USB 2.0 computer port with no problems. I've not used a USB 1.1 audio device on a computer with USB 1.1, so that's the bit I'm unsure about.jonasjar wrote:is there any big difference if the PC is USB 2.0 and the soundcard is 1.1 vs if both sides are 1.1 ??
No - it's not in the manual - or the "data manual" - or on the Roland web site. There are a lot of things that suggest that it is 1.1 as you have indicated, but the clincher was that I found the same question on another forum and someone had taken the cover off and looked at the chip to resolve the question for once and for all.jonasjar wrote:@Steve Where did you get that data throughput on the edirol from? Not from the user manual I assume?
It's probably understandable that Roland have been so cagey about it - everyone is so concerned with "specifications" these days that they overshadow whether or not the thing works. Everyone wants more megapixels on their camera and more kHz sampling rate on their sound card and more Gigabytes for their web space, regardless of what the picture/sound/hosting quality is like.
The limitation of USB 1.1 is that you can't get full-duplex audio greater than 48kHz stereo sampling rate - at least, not reliably.jonasjar wrote:All the other players seem to think that for 2-channel using
I think that the UCA-202 which I use is USB 1.1 (it doesn't appear to say otherwise, and Behringer are always very keen to shout about specifications) and it works fine for recording and playback at 48kHz. The Edirol UA-25EX is capable of recording at 96kHz (which is arguably over-kill), but it cannot be used in full-duplex at 96kHz.
That is perfectly understandable. Can you get anyone to "demo" one for you? There seems to be a shortage of genuine reviews for these devices on the internet, but if you have a good hunt around you may find some.jonasjar wrote:Sorry if I sound picky, but the thought of buying a soundcard, bringing it home and then not having it working as planned, as seem to have happened to quite a few folks, just scares me half to death.
i believe the original edirol one was 1.1stevethefiddle wrote: The Edirol ua-25 EX is USB 1.1,
but what about the new cakewalk model after the company bought out the original maker ?
vendors are claiming that that one is usb2 are they lying ?
that has happened before!
it is strange the vendors site are still silent.
pull the cover and see the chip! i love that!!
now if someone would verify the new version.
/Jonas
i say wait for usb3. almost as fast as the speed of light, faster than the speed of sound with 64 polyphonic midi instruments mixing with your 16 choir mikes and 32 f/x doing real time processing.
i say if it works who cares. for many people who try to do a *LOT* it may not work. for most recording it works fine. if you are trying to play midi and mix it with your own playing it may not do the job.
look at the emu0404 very similar but usb2.0
but if i did it again i would get something bigger (more mike inputs)
latency can be lot more than the usb depending what you want to do and the box you are using.
now cooperating with your pc is another story that is way beyond usb issues.
do you have the ex25 yet ? what problems are you having with it?
i mean besides not having any vista drivers for it ?
if not then go to kellys computer and music and use their table to compare all the devices. check out zzounds for specs and review.
google the device names and see what problems pop up.
