could be superstitionstevethefiddle wrote:Where? In both the Windows Control Panel AND in Audacity Preferences?jamie23 wrote:the recording device is set to usb codec,
Where? Which setting?jamie23 wrote:when i toggled with the configuration
but it seems that i had to set every place i found a reference to audio stuff in order to make my pc work
some of them did appear to be the same thing but several of them had other options
in particular i had to unmute and max volumes everywhere
and double check taht they all used the correct audio card
then it worked fine with audacity
