guitar USB cable
Did you buy a new mixer? Do you need advice? Post here.
Ito
guitar USB cable
Post by Ito » Tue Dec 01, 2009 8:52 pm
check this out
may help people:
http://www.provantage.com/hosa-technology-usq-110~BHOST04K.htm
Re: guitar USB cable
Post by steve » Tue Dec 01, 2009 11:05 pm
I've been looking for a review of a USB Guitar cable, but so far only found one, and it wasn't encouraging
I bought it........IT SOUNDS LIKE RUBBISH!
Does anyone here use one?
Ito
Post by Ito » Sun Dec 27, 2009 1:43 am
Hey,
I did get the Hosa cable.
It is good.
there is the delay - software playthrough - however...
I dont know if that can be helped. supposedly there is a hardware playthrough on the Mac,
and on the PC as well if you set the correct volume controls.
anyone?
take care
Post by steve » Mon Dec 28, 2009 12:05 pm
Thanks for the feedback Ito.
Ito wrote:there is the delay - software playthrough - however...
No it can't be helped. Playback it through a different device (your sound card) from recording (the cable) so there is no direct hardware connection between the two. That means that you need to use software playthrough, which it very much slower and causes a delay when listening to the sound that you are recording.
One way round this is to listen to previous tracks from Audacity with headphones or speakers and listen to the guitar acoustically. If you listen to Audacity with speakers, avoid turning the volume up too loud or you will get some bleed-through on your new guitar track.
Using a program that supports ASIO may give you software playthrough with lower latency than is available with Audacity.
