High pitched buzzing when recording
Did you buy a new mixer? Do you need advice? Post here.
Audioman
Post by Audioman » Tue Aug 25, 2009 8:51 pm
This is not a request for help but to advise of a strange recording problem and its solution.
I recently began to use audacity for recording. Whenever I tried to record there was a high pitched electronic buzz overwhelming the desired input signal :( After much playing with cables and plugs I was amazed to find that the cause was the "ethernet over the power network" box that I using. The earthing in the apartment is poor so that probably does not help but for sure with the ethernet box out of the power socket the noise was gone :D
Hope this is useful to someone
Re: High pitched buzzing when recording
Post by kozikowski » Wed Aug 26, 2009 2:03 am
<<<I recently began to use audacity for recording. >>>
That's the verb, now we need a noun. Recording....what?
