a new soundcard
Did you buy a new mixer? Do you need advice? Post here.
coonsanders
a new soundcard
Post by coonsanders » Mon Aug 10, 2009 1:21 am
hi
i think i found the problem reguarding the 0.5 and not being able to get a hight volume...its my new soundcard.one minare its low and then it goes higher...the soundcard
isnst consistant....the brand of the soundcard is encore and the model is enm232-6v1a...is there a standard for these soundcards?
lenny
Re: a new soundcard
Post by kozikowski » Mon Aug 10, 2009 2:03 am
That model number will not google.
Web site?
One of the "features" of many sound cards is to automatically set level during recording. 0.5 (-6dB) is not a bad level to do that. The sound card is going to have drivers and control software. See if they let you turn "Auto" off with a control or clicky.
Re: a new soundcard
Post by kozikowski » Mon Aug 10, 2009 2:04 am
This isn't an Audacity problem. Audacity will not apply Effects during live capture. It's a frequently asked-for feature.
coonsanders
Re: a new soundcard
Post by coonsanders » Mon Aug 10, 2009 1:09 pm
ok thanks
lenny
