ZoomH4n/H4nPro Adding Mp3 Files......
Did you buy a new mixer? Do you need advice? Post here.
RobCharles1981
Operating System: Windows 7
Post by RobCharles1981 » Mon Apr 12, 2021 10:55 am
Hi can anyone after a suggestion please?
I both have the ZoomH4n and H4nPro and want to add mp3 music files to play back but what seems to happen is after each file is played it runs onto the next file and not stopping after each track.
Is there a way around this from happening please?
Many thanks
Rob
Re: ZoomH4n/H4nPro Adding Mp3 Files......
Post by steve » Mon Apr 12, 2021 11:14 am
At the same time, or one after the other?
How are you doing that?
Played how? In the Zoom? In Windows Media Player?
Should it stop?
Is Audacity involved in this somewhere?
RobCharles1981
Post by RobCharles1981 » Mon Apr 12, 2021 11:40 am
Hi as I said,
I added the files onto the SD Card to play back in the Zoom Recorders
Audacity is involved when I had to alter the pitch key then exported......
Post by steve » Mon Apr 12, 2021 12:08 pm
Sorry but I still don't understand what the problem is that you are trying to describe, or what this has to do with Audacity.
RobCharles1981
Post by RobCharles1981 » Mon Apr 12, 2021 12:30 pm
Ile re-explain.
I transferred some MP3 Music onto my ZoomH4n Recorder to play back through headphones.
The Only edit I did to the mp3 files was to change the pitch then export as mp3 and save to my desktop.
Now when I transferred the files and played them back rather than the track ending like it should and the recorder stops, it would then run onto the other tracks.
How do I stop the recorder from running onto the next tracks?
Post by steve » Mon Apr 12, 2021 12:41 pm
Did you import multiple MP3 files into Audacity and export as one long MP3 file?
RobCharles1981
Post by RobCharles1981 » Mon Apr 12, 2021 12:42 pm
No just the one.
Post by steve » Mon Apr 12, 2021 1:10 pm
How much music? How many files and how long were they?
"files" (plural)
No just the one.
Sorry but I still can't picture what you did, what you expected to happen, or what actually happened.
Perhaps I'd understand if you described step by step what I need to do to reproduce the problem.
jademan
Forum Crew
Post by jademan » Tue Apr 13, 2021 4:50 pm
On page 95/96 section 4-02 Playback in the H4n manual, it says to:
1) Press the Menu button
2) By adjusting and then pressing the Thumb Wheel, select "PLAY MODE"
3) By adjusting and then pressing the Thumb Wheel, select "PLAY ALL" instead of "PLAY ONE"
4) Press the play button.
I hope this helps. :D
