Beringer XR18
Did you buy a new mixer? Do you need advice? Post here.
Leenanee
Beringer XR18
Post by Leenanee » Sun Mar 07, 2021 3:16 am
We went digital at church. I'm having a difficult time finding the right hook ups to be able to record the preaching. Can Audacity record over the wifi hookup with the xr18?
Re: Beringer XR18
Post by steve » Sun Mar 07, 2021 11:37 am
It will probably be easier to use the computer's built-in sound card, and since you're recording an internet stream it's unlikely that the xr18 will improve the sound quality.
See here for how to record sounds that are playing on the computer: https://manual.audacityteam.org/man/tut ... ndows.html
jademan
Forum Crew
Re: Beringer XR18
Post by jademan » Mon Mar 08, 2021 1:27 am
No. The Wifi is just for mixing - no audio.
The easiest thing is to record out of the mixer's headphone output into a stand-alone recorder, e.g. Zoom.
You could route/copy the main L/R outputs to USB 1 and 2 and record into Audacity via USB(IN 1-2 (BEHRINGER X-AIR)) via MME.
To route, on the X-AIR software, select IN/OUT in upper right-hand corner, then in In/Out window, select USB Sends then click on the GREEN CIRCLE and click in the USB 1 row underneath MAIN L, and the USB 2 row underneath MAIN R. It's best to make a note of the original settings before changing anything. If you do this, set Audacity's record rate to 48000Hz to match that of the X-AIR.
I hope this helps. :D
Leenanee
Re: Beringer XR18
Post by Leenanee » Mon Mar 08, 2021 2:06 pm
Thank you, I'm gonna give this a try
