Line only usb audio interface
Did you buy a new mixer? Do you need advice? Post here.
trevortex
Re: Line only usb audio interface
Post by trevortex » Wed Dec 30, 2020 2:46 pm
ingoogni wrote:
Tue Dec 29, 2020 7:09 pm
jademan wrote:
Tue Dec 29, 2020 3:15 pm
ingoogni wrote:
Sun Dec 27, 2020 5:53 pm
There's nothing coming from the UMC404 input as the send signal is not patched through. Signal and clip lights work.
I am not sure I follow what you are saying.. :?
Have a look at the schema (PDF), I use insert 1-4.
There are no microphones or instruments plugged in to the front inputs. So there's no signal going through the preamps. Even if there was a signal from them, the send/return jacks break the signal flow as I didn't connect the send.
By using the returns as input you go from line level straight to the DAC.
Are you even facing the error???
Post by steve » Wed Dec 30, 2020 2:56 pm
What error are you referring to?
How is your post related to the original post?
