Background Noise/Hissing with a USB Mic??
Did you buy a new mixer? Do you need advice? Post here.
archanimal92
Post by archanimal92 » Sun Nov 15, 2020 9:15 pm
Hello,
I've been having a lot of trouble removing background noise/hissing from an Audio Technica 2500xUSB Cardioid Condenser mic.
It's a brand-new mic, the room has been quietened (AC off, fridge unplugged etc), the mic has a shock mount and pop filter, I've tried muting the mic levels/lowered the gain etc. and nothing has helped. I've been using Audacity and even the noise reduction effect hasn't helped. The background noise gets louder the quieter the piano/vocals are.
Here's a 20 sec sample of that ambient noise I'm referring to: https://soundcloud.com/archanimal92/sa ... 1iHUMt7K0
My setup is basically just the USB mic connected to a laptop with a USB C to USB A cable. Nothing else. I'm not sure if it's a problem with the mic itself, the USB connection, HDD noise or something entirely different, and I would like to figure it out before returning/replacing the mic and having the same issue again.
Thank you so much in advance for your help!
-Diana
jademan
Forum Crew
Re: Background Noise/Hissing with a USB Mic??
Post by jademan » Sun Nov 15, 2020 11:00 pm
steve wrote: When seeking help with sound quality issues it is often helpful to post a short audio sample that illustrates the problem. In most cases just 3 or 4 seconds of audio in WAV format is sufficient. Note that other formats such as MP3 may not be helpful (unless the question is specifically about MP3 exports) because MP3 encoding reduces the sound quality and may make it more difficult to hear what the cause of the problem is.
Check out How to post an audio sample: viewtopic.php?t=72887
Post by kozikowski » Mon Nov 16, 2020 1:38 am
That and to do noise tests we need a portion of the test to not have any performance in it. That can get messy because you can't just "plug in" silence from the effects lists, that doesn't reflect the actual performance environment.
When the audiobook people have noise problems we ask them to read a short sentence and hold their breath for a second or two. That's the "real" background noise.
Even at that, I wasn't able to hear any hiss sounds in your music.
Can you listen to the work on something else? Somebody else's computer? It's not that unusual for a playback problem to drive everybody nuts when they think their microphone is broken.
jademan
Forum Crew
Post by jademan » Mon Nov 16, 2020 2:12 pm
Unfortunately, neither of us were able to see what you were talking about from your soundcloud posting.
You could try sandwiching the microphone between two pillows to see if the noise is coming from the microphone/computer or from the room. If the noise is still present, it could be the computer, USB connection, or the microphone. One poster on the Amazon website said: "The best option I've found [for the Audio Technica 2500xUSB Cardioid Condenser] is to use the XLR cable direct to a Digital Audio Recorder. Currently an H4N Pro."
For a discussion on Room noise, see: viewtopic.php?f=64&t=95364
Post by kozikowski » Mon Nov 16, 2020 3:11 pm
There's a trick to this, too. Don't go "diving for noise."
Set the playback volume for comfortable listening at the loudest portion of the show, and then don't touch anything while you play the whole thing. It doesn't count if you play a very soft, delicate passage and then crank the volume control up as far as it will go. Nobody would ever pass noise if they did that.
koz
