click removal question
coonsanders
Post by coonsanders » Wed May 13, 2009 11:53 am
hi
after saving the song into the computer i tried to remove the clicks with the click removel option.i played a little of the track with the preview button i noticed that the song sounded the same...the preview is supposed to tell how a song will sound at that setting but it sounded the same where ever i previewed it.what am i doing wrong?thanks.
coonsanders
Re: click removal question
Post by steve » Wed May 13, 2009 4:58 pm
Which version Audacity?
What operating system?
coonsanders
Post by coonsanders » Wed May 13, 2009 5:07 pm
hi steve
audacity version 1.2.6......for xp and intenet ex 7
lenny
Post by steve » Wed May 13, 2009 7:15 pm
Try upgrading to Audacity 1.3.7
coonsanders
Post by coonsanders » Wed May 13, 2009 8:29 pm
hi steve
will beta work 4 me?i installed it but still the preview on the cllick remover doesnt tell me anything...maybe im doing it wrongs.lets see i select all to highlight the song.....its a dark gray.this enables the different options including the click
removal...ok i move the slider and hit the preview button and theres no differance in the sound...did i do it wrong?
lenny
Post by steve » Thu May 14, 2009 4:13 pm
1) The preview button only provides a preview of the first couple of seconds (you can set the number of seconds preview in Preferences)
2) You may need to adjust the settings of the effect for it to detect and remove the clicks.
3) Do not use Click Removal as a "global effect" - just select a fairly small area that contains the clicks that you wish to remove. If you apply apply the effect to a large area of music it will probably make false detections and remove bits of the music that it shouldn't.
4) It is often easier to just apply the effect and then use "Undo" (Ctrl+Z) if it's not right rather than using the preview feature. This will allow you to "see" as well as hear if there is any change.
5) The click removal effect works quite well on certain types of click, but it is not magic. Some types of click can not be removed with this tool. One example of a type of click that is notoriously difficult to remove are clicks caused by large scratches on CDs.
6) It may be possible to remove large clicks that cannot be removed with this tool by using the Repair tool. To use the repair tool, zoom in very close on the click and select the area that contains the click. The selection must be no more than 128 samples. Then select "Repair" from the effects menu.
coonsanders
Post by coonsanders » Fri May 15, 2009 4:15 am
hi steve
thanks much...
lenny
coonsanders
Post by coonsanders » Fri May 15, 2009 4:24 am
hi
where in preferancces is the option to adjust the preview ?
lenny
waxcylinder
Post by waxcylinder » Fri May 15, 2009 9:41 am
The Audio I/O tab
coonsanders
Post by coonsanders » Fri May 15, 2009 11:12 am
thanks
