High Pitched Whining Whilst Recording
Re: High Pitched Whining Whilst Recording
As Trebor observed that noise is actually quite a bit different from the usual USB data lines interference, particularly with the shifting in pitch that is going on. I suspect it may have a different origin.
After posting the code into Nyquist prompt, you then have to apply Nyquist prompt to the audio as if it was an Effect,MrSeeb wrote:Copying and pasting that code into the Nyquist prompt hasn't changed anything by the sound of it ...
i.e. select the audio you want to process, then apply Nyquist prompt.
If it's shifting pitch, then the notches aren't going to work. The news just keeps getting better...
No shifting-pitch within MrSeeb's audio , but the ratio of the harmonics present changes with time ...kozikowski wrote:If it's shifting pitch, then the notches aren't going to work ...
Maybe an artefact of Pulse Width Modulation of the power supply ? ...
http://en.wikipedia.org/wiki/Pulse-width_modulationwikipedia.org/wiki/Pulse-width_modulation wrote:The resulting spectra (of the three cases) are similar, and each contains a dc component, a base sideband containing the modulating signal and phase modulated carriers at each harmonic of the frequency of the pulse.
I select the track, giving it a yellow outline, and then go through effect > Nyquist Prompt > C/P the code > then click OK. I've also tried highlighting the track and repeating but to no avail. I couldn't apologise more if I am doing this completely wrong, unfortunately software such as this is not my forte.Trebor wrote:After posting the code into Nyquist prompt, you then have to apply Nyquist prompt to the audio as if it was an Effect,MrSeeb wrote:Copying and pasting that code into the Nyquist prompt hasn't changed anything by the sound of it ...
Thanks for all the help everyone, it really means alot.
Well. That should have worked...
You can select a track by clicking just above MUTE.
I've tried to upload a .mp4 to show me doing it but the attachment adder isn't happy with that and keeps deleting it, so I'll give you a detailed run down of what I do. After opening the file, I click just above mute to select the audio track, darkening the selected area, I then go to effect, and click Nyquist Prompt, then copy and paste the text into the blank area. After this I click OK, nothing else and then play back the track and it hasn't changed. Sorry about the lack of ease on this, I imagine this is getting quite annoying!kozikowski wrote:Well. That should have worked...
Puzzling, more like it. Hang in while we figure out what to do.I imagine this is getting quite annoying!
"Good" news! It doesn't work for me, either.
Must be a typo in the code or some other programming damage. We need someone who can read Nyquist to figure it out.
That sounds like you're doing the right thing ...MrSeeb wrote:I select the track, giving it a yellow outline, and then go through effect > Nyquist Prompt > C/P the code > then click OK. I've also tried highlighting the track and repeating but to no avail.
NB: the whine removal code I posted is specific to the audio you posted. It won't remove any old whine,
only the whine produced by the particular apparatus you used to make the audio you posted.
I'm using an old copy of Audacity : 2.0.6 , [on Windows]. If you're using a different version that may explain why it isn't working for you, i.e. possibly a bug in a later version of Audacity, (if the Nyquist code is being copied & pasted accurately).kozikowski wrote:"Good" news! It doesn't work for me, either. Must be a typo in the code or some other programming damage. We need someone who can read Nyquist to figure it out.
