Recording over loop
kosmickopp
Recording over loop
New to Audacity. I want to use various Acid Loops as backing tracks. How do I make a loop play continuously while recording another track? While playing back a loop I can't record at all. What am I doing wrong?
Re: Recording over loop
select the audio that you want to repeat, then select "Repeat" from the effects menu and enter the number of times that you want it to repeat.
To hear other tracks while recording a new one, go to preferences (from Edit menu) and in the Audio I/O tab select "play other tracks while recording new one".
For general help with using Audacity, see the "Tips" and "Tutorials" links at the top of this page.
