Unwanted noise on recording
Re: Unwanted noise on recording
Well that test eliminates grounding as the issue. So it's most likely a fault (or poor design) of your computer's sound card.
A USB headset will probably solve the issue.
I increased the value of Capture as much as possible but it did not make any significant difference to the hum
If it worked it would reduce level of hiss relative to the signal, it would not reduce hum.gideon425 wrote:I increased the value of Capture as much as possible but it did not make any significant difference to the hum
Here's a digital solution to removing your mains-hum ...
Paste the code below into something called "Nyquist Prompt" (in Audacity Effects Menu )
Code: Select all
(setf s (notch2 s 450 25))
(setf s (notch2 s 400 25))
(setf s (notch2 s 350 25))
(setf s (notch2 s 250 25))
(setf s (notch2 s 200 25))
(setf s (notch2 s 100 25))
(setf s (notch2 s 50 1))NB: this will only remove hum , it makes no difference to the hiss.
PS the spectrogram of your "xx" hum example is consistent with an electrical-hardware problem called "impedance mismatch", i.e. you need to try a different microphone to get better sound into that computer.
I have been using the "noise removal" option in Audacity, selecting a few seconds of sound where I do not speak, to guide the removal process. This seems to work very well as the noise is almost completely gone.
It would be nice if there was an application I could run to sit between me and the SIP client, filtering out the noise.
Many computer sound-cards do have real-time noise-reduction, aka "Noise Suppression", as one of their "enhancements".gideon425 wrote:It would be nice if there was an application I could run to sit between me and the SIP client, filtering out the noise.
My card is HDA Intel (chip VIA VT2020)
There is some information here but it does not mention noise reduction
http://www.via.com.tw/en/support/tech_faq.jsp
The normal command I use to access the card is alsamixer. When I run this command, I do not see any noise reduction option to enable
Like I said I'm not fluent with Linux so , you'd have to Google real-time "noise suppression" ubuntu.
