Hello all
Quick question
What is the max record time allowed on Audacity?
And can you recommend some audio recording software (free is good but not a requirement) with a very long record time, or at least the longest you know of? Thanks everyone!
record time question
Re: record time question
Not limited by Audacity.nomrakram wrote:What is the max record time allowed on Audacity?
You must have enough available disk space.
Some users on 32 bit machines have reported problems with recordings longer than about 12 hours, but this seems to be due to the computer being unable to correctly address files that exceed a 32 bit range rather than a limitation in Audacity, so that problem is likely to be present with any recording software.
