Yeah, sure i do it. but when i applied, even changing all variables, there is not a notorius change, or maybe i can ear it.Trebor wrote:The plugin is supplied in the zip file format, it has to be unzipped (unpacked/extracted) and the "widener.ny" file put into Audacity plugins file, same as you did with Anwida DX Reverb Light ...gadox13 wrote:... I tried to use this plugin but it doesnt work, not process the audio, just show a log window.
After you put an effect into the Audacity plugin folder, tick all the boxes here, then restart Audacity, (i.e. off then on again).
But thanks for the help, finally i get it with a some simply reverb.
The voice of my friend is a kind harsh. The recording is going great!
oh! , i need other help. do you know a plugin to change the pitch, dinamically. i mean in some portion a pitch decreases or grow up, since the start to the end. or better choose the pitch values with a graphics like a equalizer.
Regards
