Zoom Q3HD Recorder - Best Sound Settings
Gordon7799
Post by Gordon7799 » Wed Dec 28, 2011 4:18 pm
Good morning, folks.
I received a Zoom Q3HD camcorder for Christmas.
I want to use it to record my young grandson who plays in a band and would appreciate some help setting it up for the best sound results. I know very little about the options.
I have two options for Format - PCM and AAC. Is PCM the best choice?
Regarding Sample rate, the 3 options are 44.1, 48 and 96kHz. I presume the higher 96kHz is the best pick .... Right?
And finally, I can select either 16 bit length or 24 bit length. Should I select 24?
So, the bottom line would be .... PCM, 96kHz and 24 bit length.
Is this how the pros would set it up. I know very little about the above options so would dearly appreciate your feedback.
Thank you!
Re: Zoom Q3HD Recorder - Best Sound Settings
Post by steve » Wed Dec 28, 2011 4:31 pm
PCM, 96kHz and 24 bit is a very high quality format, but the file size will be huge and the flash memory may struggle to keep up with the amount of data.
Try a test recording with PCM. 44.1 kHz 24 bit and see how that goes (the recording quality is virtually identical, but less than half the amount of data).
Gordon7799
Post by Gordon7799 » Wed Dec 28, 2011 4:37 pm
Thank you, Steve!
