One recorded channel louder than the other [SOLVED]
cheere steve!!!
see what i noticed aswell!!!
speaker icon--- right click: Recording Devices:Double Click On Your Sound Card---Advanced
i have this as Default Mode
1 Channel,16 Bit.44100 Hz (Cd quality)
this setting Is Fine For Me
i notice if i change this to 2 channel, the 2 channels are not equal when i am recording...
select the sample rate And Bit Debt when running in Sharded Mode
not Quiet Sure What That Means...hehe
Reason: give more relevant title
Re: SHOW CLIPPING
If you want to record in stereo, then that should be set to "2 Channel".jb3funk wrote:i have this as Default Mode
It's not unusual for the left and right channels to be at slightly different levels from a turntable, but if they are a long way out then there may be something wrong.
Re: SHOW CLIPPING
weird cause my recordings are All in stereo and that setting is at 1 Channel,16 Bit.44100 Hz (Cd quality)
Strange One!!!
Strange One!!!
Re: SHOW CLIPPING
Are you sure that they are actually stereo and not just 2 identical (mono) channels?
Re: SHOW CLIPPING
well according to the audio properties: Channels 2 (Stereo) right click on the track
how do you check to see if it is stereo?
when i play them bk via foobar: it says stereo aswell
Re: SHOW CLIPPING
Two ways of doing it:jb3funk wrote: how do you check to see if it is stereo?
1) If you record something that has a distinctly stereo sound (the left and right sound distinctly different), then you can just listen to the recording to see if the left and right channels still sound distinctly different.
2) You can check if the two tracks are identical (mono) by applying the "Vocal Remover" effect. If the two channels were identical then the result will be silence.
Re: SHOW CLIPPING
here is a pic of one of my recordings....i record my records at -6 as you said to me the last time,and also you can see where it says stereo aswell
Re: SHOW CLIPPING
Yes, Audacity is recording as stereo - that is, the sound that it is receiving is being recorded to two channels (left and right), but if Audacity is receiving mono sound, then both the left and right channels will be identical.jb3funk wrote:and also you can see where it says stereo aswell
Possibly a good example of what I mean is CDs. CDs are always recorded as stereo tracks, but let's say that you have a CD of a 1920's recording. Back in the 1920s stereo had not been invented - all recordings were mono. If a mono 1920s recording is re-released on CD, then although the CD format is stereo (like your pictured stereo track) the actual sound will still be mono (both left and right channels will be identical). The tests that I mentioned are to test if the actual sound is mono or stereo.
Re: SHOW CLIPPING
when i did the vocal remover effect.... for center- panned vocals
i got the Picture Above...
Is That Right Steve?
So Its Stereo So yes?
Re: SHOW CLIPPING
Apart from a couple of clicks, that looks like silence.
steve wrote: If the two channels were identical then the result will be silence.
