No effects when recording with multi effects processor?
Re: No effects when recording with multi effects processor?
Ah that makes sense. Ok I understand now thanks all for the info I'll let you know what happens!
Before you buy a soundcard, double-check the connection to your pedal.
Apparently the pedal has two outputs: one with effects (“wet”) and one without (“dry”).
If you are feeding the “dry” channel to your computer it won’t have any effects.
http://www.voxamps.com/forum/forum.php?id=33
[email protected]
I'm having a similar issue. In my case however, I can hear the effects play when I plug into the headphone control room out but it is not going to my main outs. When I listen to the headphones I hear the effect on top of the raw signal but when I turn up my amp which is connected to the main output I get no a effect, just The raw signal. Do I have a setting wrong?
You replied to a VERY old post... It's also a bad idea to post your email on the Internet.
Exactly what hardware are you using?
