Auto-record is a neat feature but it cuts off the first 500-1000ms.
Any solution?
Autorecord cuts off first 1000ms
smeezekitty
- Quality Assurance
Re: Autorecord cuts off first 1000ms
Audacity doesn't have a feature called "Auto-record". If you mean Sound Activated Recording in 1.3 Beta, it doesn't have a pre-roll, so you can't do much except possibly:smeezekitty wrote:Auto-record is a neat feature but it cuts off the first 500-1000ms.
- Reduce the activation level (move the slider left) at Transport > Sound Activation Level (this may or may not help)
- If you are on Windows, change the "Host" to Windows DirectSound in the Devices Preferences, which might reduce the latency
- In the Recording Preferences, reduce "Audio to buffer" slightly (this may cause dropouts) - the default is 100 ms
smeezekitty
That's exactly what I meant.Gale Andrews wrote:Audacity doesn't have a feature called "Auto-record". If you mean Sound Activated Recording in 1.3 Beta, it doesn't have a pre-roll, so you can't do much except possibly:smeezekitty wrote:Auto-record is a neat feature but it cuts off the first 500-1000ms.
Does not help.[*] Reduce the activation level (move the slider left) at Transport > Sound Activation Level (this may or may not help)
Slightly better but still clips.[*] If you are on Windows, change the "Host" to Windows DirectSound in the Devices Preferences, which might reduce the latency
[*] In the Recording Preferences, reduce "Audio to buffer" slightly (this may cause dropouts) - the default is 100 ms [/list]
- Quality Assurance
Does that mean it doesn't help, or you don't know what to change? What are you recording, with what equipment, and how is it connected to the computer? I don't lose more than about 100 ms when doing Sound Activated recording. What results do you get if you do this latency test ?smeezekitty wrote:Gale Andrews wrote: In the Recording Preferences, reduce "Audio to buffer" slightly (this may cause dropouts) - the default is 100 ms
