Hello. I was wondering if there was a more efficient way to loop a sample (imported audio file) in Audcaity, besides copying/pasting a sample over and over again, having to match each occurrence with the beat? Perhaps there's a plug-in out there or something?
What I've done in the past is used the Echo tool and set it so that there was no decay, but there is a slight gradual decay, anyway.
Any Ideas?
Sample looping/Sequencing
Re: Sample looping/Sequencing
This post has a reference to Effects > Repeat. That might work for you
http://audacityteam.org/forum/viewtopic ... ree#p10886
Wow... there's a "Repeat" effect now? Is this new in 1.2.6.?
Thanks!
Thanks!
