Hi everyone.
I have just got a Usb turntable with the Audacity software. There is no manual with it so I am flying blind.I have recorded a few tracks and have worked out how to export it in mp3 format to my mp3 player,but when listening to it it sounds a bit `tinny` almost as if the tone level is too high.Please does anyone know if there is a way of reducing it?
Can you adjust the tone and bass levels?
Re: Can you adjust the tone and bass levels?
Hi,
a similar question was posted a few weeks ago,
http://audacityteam.org/forum/viewtopic.php?f=26&t=2350
although not exactly the same problem you should find some answers.
Baically if you go tho the effects drop down menu there is an option for setting the eq. have a play and youll be able to improve the sound greatly.
cheers
cheers
Yes, but.
The voices in my head are yelling that it shouldn't be tinny in the first place. If you play Audacity after the capture but before the export, does it sound OK?
