recording quality
recording quality
hi, im a dj and have started using audacity for recording my mixes im using pioneer cdj1000s and djm 700 and recording from my mixer (phono cable-mini jack)to a trust external sound card as my laptop has no line in.. the sound quality is good but now and then when i listen back to my recorded mix it has little glitches in the sound like a needle jumping on a vinyl turntable and also seem to pick up soom slight distorted sound like when a tv has lost its signal (white noise style). any ideas how to stop this happening? cheers chris
Re: recording quality
It sounds very much like a USB problem.
Some general tips:
* Check the Project Rate bottom left of the Audacity screen is set to either 44 100 or 48 000 Hz - setting a very high rate might overload the USB bandwidth and cause transmission problems
* Check the USB cable for tightness at both ends and try using a different cable instead
* Always use a spare USB port, not a hub
* Limit USB bandwidth whilst recording by using other USB devices sparingly e.g. simply disconnecting from the internet may help if you use a USB modem for internet access.
* Check for any system warnings (e.g. in Device Manager in Windows) about the Universal Serial Bus Controllers.
Also, see here: http://wiki.audacityteam.org/wiki/Manag ... nd_Drivers
Some general tips:
