multiple tracks problem
I'm new to using audacity. I have recorded an album, labeled the individual songs, and did the export multiple. Everything seemed to work, but when I pull up the album the first song isn't there. I transfered it to Media Player, and all of the other songs are ok. I noticed that the properties for this shows a size of only 44 bytes, while the other songs have a size of, say, 73.0 MB.
Any idea what happened?
Thanks in advance.
Thanks in advance.
waxcylinder
Re: multiple tracks problem
You have created a label for the first track right at the beginning of the project?
Label at the first track - Yes I have.
waxcylinder
In which case it should work - odd!
Workaround - select the first track and try Export Selection.
Thanks for the idea. I'll give it a try.
Now that's weird. The export selection worked. Any idea why it didn't work as export multiple?
waxcylinder
None at all, sorry ..... but glad it worked
