Recording voice with USB
valis
Post by valis » Tue Jan 26, 2010 11:50 am
I will buy an TERRATEC AUREON DUAL USB, a little pen with soundcard and line in for mic, can I register Voice with the this Usb in Audacity?
Thank you
Irish
Forum Crew
Re: Recording voice with USB
Post by Irish » Tue Jan 26, 2010 2:12 pm
Yes, you can, but you could equally just use the mic input on your computer. The "technical data" section on the manufacturer's website is conspicuously lacking in technical detail for that device, but I would imagine that it expects a standard computer microphone as an input, which is the same as the mic input on your computer expects. There is probably a 50-50 chance that it will have a better quality sound card than your computer. If you are going to buy it anyway, try both options and see which is better.
In general, for choosing recording equipment, a lot depends on what you want to record, and what quality you want.
For speech you will probably get by with a cheap computer mic. For music or singing, you may want a better quality mic, in which case you are getting into the territory of pre-amplifiers, and things get a little more complex. If you do go that way, there are a number of people on the forum who will be glad to point you in the right direction.
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
valis
Post by valis » Tue Jan 26, 2010 2:24 pm
Thank you....but read audacity automatically this external soundcard?
Irish
Forum Crew
Post by Irish » Tue Jan 26, 2010 9:48 pm
Yes, Audacity will read the soundcard, provided your computer's sound system recognises it.
You will need to do the following:
Plug in the sound card before you start Audacity.
Go to Audacity Preferences (in Version 1.2, Edit > Preferences > Audio I/O. In version 1.3 Edit > Preferences > Devices) and select USB Audio Codec as the recording device and your computer's sound system as the playback device.
PO'L
