So I'm trying to record my vinyl. Everything worked fine with my desktop. With my new laptop however I don't think my recordings come out right. When I try to record something it comes out as really loud, and the recording spikes are huge and I can't figure out how to fix the problem. I adjusted my microphone recording volume and now I'm stuck since that didn't work at all.
please someone help me =[
I desperatly need help with my recording levels =[
pikachuiscute
waxcylinder
Re: I desperatly need help with my recording levels =[
You will need to tell us a lot more about your setuo - remember we can't look over your shoulder.
What computer, which operating system, version of Audacity, soundcard, turntable (a USB TT perchance)? We thrive on detail
pikachuiscute
ok i have a sony vaio laptop, with windows 7. I'm running the current version of audactity. my turntable is a technics with a technics amp, I have it recording through a cable plugged into the amp. It's basically a headphone plug to headphone plug cable(not sure what to call it). This set up worked fine with my desktop but won't coorperate with my laptop.
There are two things happening here:
First, if you are using the headphone out jack of the amp (which it sounds like from your description), the signal level will depend on the volume setting on the amp. There should be a "line-out" socket on the amp - or more usually two sockets, red and white, for left and right - which will give you a proper line-level signal to go into your computer, and it will be independent of the amp volume setting.
Secondly, most laptops only have a mic-in jack, which is looking for a tiny mono signal from a microphone, and you are feeding it a line-level stereo signal from the amp which is overloading it.
Look at this thread:
http://forum.audacityteam.org/viewtopic.php?f=27&t=9477
which has reviews of sound cards which work well with Audacity.
BTW, more detail about your setup might help us help you; model number of your amp? which Sony Vaio? which version of Audacity? (the current version 1.3.11 is recommended for Windows 7). It's difficult to give us too much detail.
PO'L
That's because the desktop had a line-in jack, designed to take the high-level stereo output from your amp. Unless you are one of the lucky few whose laptop actually has a jack which is capable of switching from Mic to Line-in (look in Control Panel > Sounds and Audio), your best bet is to get an external USB sound card and plug the output from your amp into it.pikachuiscute wrote:This set up worked fine with my desktop but won't coorperate with my laptop.
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
pikachuiscute
thanks so much for all of your help. I'm pretty sure that I'm going to have to buy a usb soundcard. which won't be too bad if I have to get a new laptop ^.^
