saving a project
anrogeorge
saving a project
Post by anrogeorge » Thu Dec 10, 2009 8:04 pm
We tried to record for the first time, I can't save my project. Neither save or save as. I have lots of hard drive space. It will not export to my cd burner either. Do I need to reinstal?
Re: saving a project
Post by steve » Thu Dec 10, 2009 8:23 pm
anrogeorge wrote:I can't save my project. Neither save or save as.
Why not? What happens?
If you get the "Metadata Editor" window pop up, just click "OK" on it.
anrogeorge
Post by anrogeorge » Mon Jan 04, 2010 6:44 pm
It saves the files but when I try to retrieve them later, it says files not advailable.
When I send to cd burner it says cd recorder not advailable.
Post by steve » Mon Jan 04, 2010 8:49 pm
You may be experiencing the common confusion about "Saving Projects" and "Exporting Files".
Audacity Projects are made up of 2 parts - a project file (filename.aup) and a data folder filename_data
Both parts are required for an Audacity Project.
Audacity Projects are NOT audio files.
To produce an audio file you must "Export" the audio from Audacity.
If you are wanting to make an audio CD you should Export as a 16 bit WAV file with a sample rate of 44100 Hz.
Here's a couple of articles that may help:
http://wiki.audacityteam.org/index.php? ... ement_Tips
http://wiki.audacityteam.org/index.php? ... uter_or_CD
