Hi I have sorted it - thank the Lord!
I was put off by the
Metadata Editor prior to the 'Export Save in' dialog box...it wasn't until I unchecked the box which
reads...
Show Metadata Editor prior to export step in the Import Export preferences. You see I was looking for the option in
File>Export>option of WAV or mp3 as in the 1.2.6 version
it now shows;
C:Program FilesLame for Audacitylame_enc.dll
I had to re-install Audacity 3 or 4 time because my PC kept 'remembering' the lame_enc.dll location which was part of my original
1.2.6 set up which I had previously re-vamped when I learned how to use and record in stereo i.e. two channels
Anyway all's well that ends well. I will now go higher up the learning curve abd return as and when.
So thanx a bunch to you for you help
cfm
